When hot (warm this time of year) I have quite a whine, under load, that seems to be equal in all gears. It increases with throttle load, is less noticeable at constant speed and disappears when I back off. It seems to get less in the higher gears but I think it because I can't hear it as well as speed increases.
I have had boxes that where noisy in some gears and quiet in others, so I would think that that was gear noise. The pitch of this noise is RPM specific, so I am thinking input or intermediate shaft bearings, but it is a whine not a rumble. Could it be the gears on the input and or intermediate shaft?
Those of you who have replaced trans bearings, what where the symptoms that made you do the job?
