Can a /6 starter relay replace the dreaded /5 Relay?
Discuss all things 1970 & later Airheads right here
jjwithers
Post by jjwithers » Sun Jun 18, 2017 6:48 pm
It is a 72 R75/5.
The typical 'chirping' or 'clicking' issue.
I have read about the various options of modifying the /5 relay, or replacing it with a modern relay but you will void the starter prevention while the bike is running.
I can't get any clear information on swapping it was a /6 relay though. Will using a /6 relay work, and still prevent the starter from engaging while the bike is running?
-J
www.beemersandbits.com
'66 R60/2
'72 BMW 2002
Instagram - jj_withers
Re: Can a /6 starter relay replace the dreaded /5 Relay?
Post by Kurt in S.A. » Sun Jun 18, 2017 7:03 pm
Snowbum never mentions the use of a /6 relay in place of the /5 relay. His web article is all about modifying the existing relay. If it was a simple matter of using a later relay type, I would think he would have offered that as a possible solution rather than getting into the /5 relay.
Post by Rob » Sun Jun 18, 2017 11:27 pm
Every time I heard clicking, it was due to not enough power getting to the starter, either due to a low battery, or corroded connections, somewhere.
But I know nothing about /5 relays.
Post by melville » Mon Jun 19, 2017 5:52 am
The starter lockout was a dubious protection anyway. Matt Parkhouse, in an old issue of ON, showed how to use just a regular 30A relay that can be bought at any auto parts store rather than the special $100+ BMW relay. This was published just as I was dealing with a dead relay myself. I set up my /6 that way and it's been just fine ever since. Here's a link:
viewtopic.php?f=1&t=148&p=27077&hilit=woo+hoo#p27077
jjwithers
Post by jjwithers » Mon Jun 19, 2017 11:14 am
Yes, I have read several articles on using a typical modern relay but this bike is not for me, and I'd like to retain the starter lockout if possible. Which, in my readings, seems that the only way is to modify the /5 starter relay.
'66 R60/2
'72 BMW 2002
