voted best answerKurt in S.A. wrote: ↑Sun Aug 13, 2017 4:34 pm The boots do have notations for front (getriebe fortransmissiongearbox) and top (oben).
Drive shaft boot leak
Re: Drive shaft boot leak
Check for cracks on the flange.--RG
- Zombie Master
I think I figured it out: The clamp normally would have an extension piece spot welded to the clamp in order to maintain clamping pressure in the area not covered between the screw and threaded attached nut. The spot weld mark is there, but the piece is gone. I've attached the thin tapered end of a zip tie to cover that distance and it seems to be dry so far. I will order some new clamps. I wonder if a zip tie alone, could be tightened enough to seal the boot.
A couple of zip ties should work. --RG
You lost your clamp extension. Mine's been loose for twenty years. It requires a special technique to get the little bastard back in when tightening the clamp.
That'll be your leak.
I had never seen a clamp come apart. I never would have suspected that.
- Zombie Master
Yea I lost the extension. Trying to order new clamps from the stealer.
