R1100 Valve cover bolt removal
ibjman
Post by ibjman » Wed Dec 18, 2013 4:19 pm
I need to take the valve cover bolts/sleeves combination out of a damaged cover.
How do you get these rubber sleeves (and bolts) loose from the cover?
Thanks, Ibjman
Re: R1100 Valve cover bolt removal
Post by Major Softie » Thu Dec 19, 2013 1:20 am
Number 9?
I'm pretty sure they just slip in. After being in there a long time they just don't come out easily. It's been quite a few years since I replaced a valve cover, but I'm pretty sure the inserts were just stuck on there from heat and time.
ibjman
Post by ibjman » Fri May 30, 2014 1:46 am
Thanks. You are correct......the rubber sleeves just "pop" out from the inside with the bolts attached.....
