Getting close!
- Airbear
Re: Getting close!
I wonder if the front wheel motor is there to regenerate as much power as possible from braking, given that the front wheel is doing most of the braking work. The extra unsprung weight would certainly be an issue though.
Re: Getting close!
Every year technology can make things lighter. I wear a full face helmet that weighs in at 1200 grams. What a relief!Airbear wrote:I wonder if the front wheel motor is there to regenerate as much power as possible from braking, given that the front wheel is doing most of the braking work. The extra unsprung weight would certainly be an issue though.
Re: Getting close!
That was my first guess too, but it just doesn't seem worth the complexity/weight penalty, not when you can generate a lot of that from braking the rear wheel. Still, it's the only really useful purpose I can see for it on a street bike.Airbear wrote:I wonder if the front wheel motor is there to regenerate as much power as possible from braking, given that the front wheel is doing most of the braking work. The extra unsprung weight would certainly be an issue though.
I would think it would be possible to make an electric generating brake lighter than something that can do both, but perhaps it's close enough that there's no point making it just a generator.
Re: Getting close!
The front wheel drive Yamaha uses a light weight hydraulic system to power the front wheel. The front wheel would only apply power when the rear isn't hooking up, as I remember. I can't see why that couldn't be the case with an electric system.
Last edited by Zombie Master on Tue Oct 20, 2015 10:43 pm, edited 1 time in total.
Re: Getting close!
Given that an electric motor is virtually the same design as an electric generator, I imagine it would be possible for the hubs to be dual purpose; both generating going downhill, both under power going uphill and a combination of both when the opportunity arises.
