I followed the headlight wires from the handlebar switch. I am trying to figure out which wire is the power source that I should interrupt for the relay. The relay has connections for interrupting between the headlight wires (both low and high beam) and also a ground. I just can't determine which is the power wire I should tap into. There are not many wires that come out of that particular loom. I see a green/red wire and I am initially thinking this is the one.
In the picture in the forefront is the headlight white/yellow and brown ground wire that split off the loom from the switch. I got that. But you will also see two other wires at the top left that are yellow and a red/green wire that feeds into a wiring block. I was thinking red/green is the one power wire from the headlight handlebar switch.
I would like to put small fuses in as well, but have no idea what wires as things are somewhat altered. What wires should they trace back to? If I know the origin, I guess I can go from there and trace back to the headlight shell. The colors may be totally different from what is in there .
Any help is appreciated...
![Smile :)](./images/smilies/icon_e_smile.gif)
