75 r90/6 FUSE VALUES?
Rohls
Post by Rohls »
Hi,
So I've searched around with no avail; what are the fuse amp values for a typical airhead? Are they all 8A? I keep blowing the brake light/horn/turn signal one recently and the manual hasn't been very helpful in answering my questions...
Any help is appreciated!
Thanks,
Nick :D
1975 R90/6 75K and climbing
1977 R75/7 75K and holding
Re: 75 r90/6 FUSE VALUES?
From Haynes, should be two 8A fuses...ceramic I believe were the originals.
Kurt is correct...............as usual, except when he disagrees with Diane.
Duane Ausherman wrote:Kurt is correct...............as usual, except when he disagrees with Diane.
I try not to do that...we all do not want to upset Diane! :lol:
8A is what we VW folk know as the "white" fuse. Red in the same size is 16A, and blue is 25A.
Yes, they are white. It could be fun to remove a white one and use a red magic marker on the ceramic.
Duane Ausherman wrote:Yes, they are white. It could be fun to remove a white one and use a red magic marker on the ceramic.
Does that double their capacity?
MS, no, one would have to wrap it in tin foil for that. It doesn't take much. A gum wrapper or cigarette package should supply enough.
Duane Ausherman wrote:MS, no, one would have to wrap it in tin foil for that. It doesn't take much. A gum wrapper or cigarette package should supply enough.
Ah, now for the search for red foil....
richard t
Post by richard t »
Nick how often does the fuse blow?
