I have been offered a 16mm master cylinder assembly VERY cheap and in great condition. This is from an 83 airhead.
Reading the posts on this conversion it seems that 13 mm is the favoured option but can someone please in laymans terms explain to me the difference that i will experience if i use 16mm as against 13mm. The term " wooden feel " is often used when referring to the use of a larger MC.
Does this mean that the lever requires more physical effort to impart the same braking force as a 13 mm OR does it mean that the brakes have little feel and are over sensitive ie easily lock the front end up.
Thanks Darryl
![Confused :?](./images/smilies/icon_e_confused.gif)
