The complexity of the repair depends on the value, condition and intended usage of the bike.
I wouldn't rule out JBWeld, you might be pleasantly surprised, and for less than $10.
If done right it won't show. just put the stem in the exact position needed before it cures.
At worst, it'll keep you going until you get the right taps and dies.
LH Mirror Thread Repair
Re: LH Mirror Thread Repair
As an alternative to a Timesert, I found this. Requires a 9/16-12 tap. Can probably drive it in with a big screw driver.
https://www.zoro.com/e-z-lok-thread-ins ... /G2576463/
Hmmm. I'll have to check out the timesert and the zoro ez lock ( I am assuming because it has a "l" at the end that the zoro it is left threaded). It looks like you drill the hole with the correct size drill bit and then pound/drive in the insert in - no need to actually tap/thread the hole, right? If worse comes to worse, I will fall back on the JBWeld - I do appreciate that input as well. I forgot to take a few pics yesterday. Will try to remember today just so you guys and see what the deal is visually. Thanks!
Careful... I think the 'l' is for length, there is nothing in the advert to suggest that it's a left handed thread.hudson wrote: ↑Tue Dec 08, 2020 10:08 am Hmmm. I'll have to check out the timesert and the zoro ez lock ( I am assuming because it has a "l" at the end that the zoro it is left threaded). It looks like you drill the hole with the correct size drill bit and then pound/drive in the insert in - no need to actually tap/thread the hole, right? If worse comes to worse, I will fall back on the JBWeld - I do appreciate that input as well. I forgot to take a few pics yesterday. Will try to remember today just so you guys and see what the deal is visually. Thanks!
Good to know. Appreciate it!
Here are a couple pics...
- IMG_0048.JPG (343.82 KiB) Viewed 622 times
- IMG_0047.JPG (1.07 MiB) Viewed 622 times
