Pulled Cylinder Stud
Posted: Mon Jul 25, 2011 5:47 pm
by MCboston
Unfortunately I have to repair a pulled cylinder stud on my 1992 R100GS. It is the right side, top exhaust which also holds the rocker assembly. The helicoil installed by a previous owner has sheared the threads off inside the case hole which measures +-11mm inside diameter. I am trying to refrain from drilling as there is not a lot of metal between stud hole and piston opening and just tapping new threads.
Please help me out with info, specifically which insert to use etc., thanks.
Re: Pulled Cylinder Stud
Posted: Mon Jul 25, 2011 6:28 pm
by Garnet
There is a pretty good thread here: http://boxerworks.com/forum2/viewtopic.php?f=1&t=466
and a good pictoral by Frog here: http://picasaweb.google.com/blaisedesco ... 7sKaptKfQA#
Posted: Mon Jul 25, 2011 6:29 pm
by Deleted User 62
http://www.cycleworks.net/ sells a tool for fixing pulled studs ($$$$$) and the correct inserts.
Posted: Mon Jul 25, 2011 6:56 pm
by MCboston
One of the local airhead gurus told me that since the helicoil stripped the case nothing else will fix it and I have to replace the case?
Posted: Mon Jul 25, 2011 7:10 pm
by Garnet
The case saver inserts and the other brand used by Frog are a lot bigger than Heli-coils, so I believe they can reapair the stripped Heli-coil. I think that is covered in part of that long thread.
by MCboston
Garnet wrote:There is a pretty good thread here: http://boxerworks.com/forum2/viewtopic.php?f=1&t=466
Thanks, but that does not address my issue of the previously installed helicoil striping the case
Posted: Mon Jul 25, 2011 7:14 pm
by MCboston
Ok thanks, I will investigate these case savers
Posted: Mon Jul 25, 2011 7:38 pm
by esman100
The Timeserts are much larger as mentioned above and I'm certain that they will work. If it doesn't then you can have an oversize insert machined at a machine shop or look at many other standard oversize insert sources. I would not replace the case.
Posted: Mon Jul 25, 2011 11:48 pm
by MCboston
esman100 wrote:The Timeserts are much larger as mentioned above and I'm certain that they will work. If it doesn't then you can have an oversize insert machined at a machine shop or look at many other standard oversize insert sources. I would not replace the case.
With very little aluminum left between stud hole and cylinder opening I am trying to keep the insert size minimal, but appreciate any input and will have a look at the timeserts you mentioned. Any idea why Snowbum is against them?
And yes, I will try anything short of replacing the case as the engine as a whole is in great shape.
Posted: Tue Jul 26, 2011 1:11 am
by Ross
Same thing happened to me. Read and weep.... http://rossmz.blogspot.com/search/label ... der%20stud
