R80/7 Fuel Tank
shakyone
R80/7 Fuel Tank
Post by shakyone »
I recently had my fuel tank stripped in an acid bath and relined with an epoxy liner. I then spent too many days priming, painting, clearcoating, pinstriping, clearcoating again and buffing. When I went to install the tank I realized that the fuel line connector threads were too badly damaged from acid washing to get a good connection to the fuel valves-The remaining threads crumbled.
I know that one option is to use fuelproof hose to connect the valves to the tank, but I wondered if anyone else has had this problem and came up with a better solution. Remember that welding or soldering is not possible due to the new paint and liner.
Also, does anyone know the thread size of the fuel line attachment on the tank?
Thanks,
Paul
P.S. Also posted this on the airheads list
Re: R80/7 Fuel Tank
I'd be searching through all the manufacturers for a larger petcock so I could re-cut those threads to fit.
jagarra
Re: R80/7 Fuel Tank
Post by jagarra »
I would be checking out what thread pitches are available from Heli-coil and looking for a matching petcock.
There is also another possibility using nutserts, which provide a sturdy inserted thread into a thinner material.
I have attached a link to one style of these devises. There a many manufacturers and designs
http://avkfasteners.com/products.AR.php#benefits
Looks like these go only to a 10mm bolt diameter, possibly there are other manufacturers out there. The killer on these type of inserts may be the cost of the installation tools, sometimes they are specially designed. The ones I am using currently just require a long bolt and a spacing collar so the bolt grabs the threads and pulls the unit tight into the opening.
esman100
Re: R80/7 Fuel Tank
Post by esman100 »
Can you post a pic of the damage?
Jeff
Washougal, WA
'76 R90/6 "Eva"
'62 R60/2-R75/5 Conversion
Re: R80/7 Fuel Tank
A machine shop can do the insert for you, and that will save the cost of a kit or installation too. Just getting one done on something that is simple to carry into the shop might be cheaper than getting the kit. Just make sure you specify a liquid-tight insert when you are calling around, as some are and some are not.
shakyone
Re: R80/7 Fuel Tank
Post by shakyone »
Here's an update.
I was able to tap the inside of the outlet bosses on the tank to 3/8-18NPT. This will allow me to use a wide variety of petcocks.
Thanks for all the advice.
Also, What would be good to use as a sealer on the new petcock threads. I need something fuelproof, but not permanent.
Thanks,
Paul
Re: R80/7 Fuel Tank
Teflon tape? It's designed to work with tapered pipe thread joints.
shakyone
Re: R80/7 Fuel Tank
Post by shakyone »
Here's a pic of the finished repair:
Uploaded with ImageShack.us
Paul
Re: R80/7 Fuel Tank
Somewhere, some concourse restorer is spinning in the grave which he has not yet entered. But, hey, it works, and that's what it's all about. :mrgreen:
Congratulations!
Re: R80/7 Fuel Tank
That's a beautiful repair Paul, but I'm afraid it won't work. :ugeek:
Well, it will be fine at idle, but at speed the wind will prevent the fuel from falling into the fuel line. Well, unless the wind blows the fuel line back proportionately as well. :ugeek:
Perhaps a funnel? :idea:
