ATF ?
ATF ?
So my Honda Hawk manual says "ATF or equivalent".
What would be the equivalent :?:
Are there shortcomings to using ATF, or did someone think: "Hey! We could sell them fork oil"?
Re: ATF ?
Automotive hoists usually call for AW32 or ATF as a hydraulic fluid.
Re: ATF ?
dougie wrote:So my Honda Hawk manual says "ATF or equivalent".
WTF is almost the same. :geek:
Re: ATF ?
WTF?
Re: ATF ?
Major Softie wrote:WTF?
The one I know is from the first link, the one with the expletive:
http://www.internetslang.com/WTF-meaning-definition.asp
But there appear to be other meanings:
http://acronyms.thefreedictionary.com/WTF
Let the degradation begin!!
Re: ATF ?
Already been suggested.
Re: ATF ?
An equivalent of ATF would be approx. 7.5 wt fork oil.
In the same way proper motorcycle oil can't have friction modifiers because it has to allow clutch plates to grip, transmissions also have clutches and brake bands so ATF must have the same restriction. Thinking that minimum friction is what good forks are about I wonder if ATF is as slippery as proper fork oil ?
Having said that ATF was used in forks for many years and it is a nice color.
montmil
Re: ATF ?
Post by montmil »
Brings back memories of the mid-60s when I was working at a Honda dealership while going to college.
One of my jobs, besides uncrating and assembling the new Hondas, was to drain out the fish oil in the front forks -and that stuff did stink- then replace it with the good stuff. We used Bel-Ray at the time.
1981 R65
1983 R65
1978 R100S
1995 Triumph Trophy
Re: ATF ?
So far 7.5 wt has one vote.
I could not find a definitive answer using google.
And the rest of you clowns - WTF :?:
Motorhead
Re: ATF ?
Post by Motorhead »
isnt atf 12wt to 17wt an that the reason NOT to used it...
