What's the Preferred Fuel Line Crossover Method?
I'd like to run tees off my petcocks to have mutual fuel lines to both carbs. I have seen tees and lines run behind the airbox; over the top of starter cover; through starter cover...... Is there a preferred method for running crossovers?
Re: What's the Preferred Fuel Line Crossover Method?
Why not use the BMW method?
- Jeff in W.C.
And what would that be?chasbmw wrote:Why not use the BMW method?
Not that I'm an expert, but almost every bike I've seen (airhead that is) has it running behind the airbox.
Jeff in W.C.
1988 R100 RT
2018 R1200 GS
1988 R100 RT
2018 R1200 GS
The usual BMW way is to run the crossover fuel line between the lower front of the airbox and the gearbox.
http://www.advrider.com/forums/showthread.php?t=703807
I've always preferred the "X" fittings
as used by Moto Guzzi
but BMW's (as stock) "H" routing
is well suited to the powerplant's geography.
- Airbear
I run mine around the back of the clamshell airbox. It's just easier.
BMW made holes in the airbox just for the fuel lines. By far the most important aspect is to make sure that one has enough fool flow to insure that a low point in the line isn't clogged up.
I got that in spades.Duane Ausherman wrote: By far the most important aspect is to make sure that one has enough fool flow
Rather.ME 109 wrote:I got that in spades.Duane Ausherman wrote: By far the most important aspect is to make sure that one has enough fool flow
MY crossover line looks to be made of different material, has no cloth covering. What is used as a replacement?
