These s/hand rockers were essentially unworn, other than these fine facets across the contact area. The cause of the facets is open for discussion.
I wasn't content to install these without resurfacing. My attemps to find one of the local engine reconditioners capable of performing this task proved futile.
![Image](http://i277.photobucket.com/albums/kk42/jeffr100rs/DSCN1596.jpg)
So I made my own.
![Uber Geek :ugeek:](./images/smilies/icon_e_ugeek.gif)
![Image](http://i277.photobucket.com/albums/kk42/jeffr100rs/DSCN1628.jpg)
![Image](http://i277.photobucket.com/albums/kk42/jeffr100rs/DSCN1661.jpg)
A squirt of oil on the plate, and a squirt down the rocker shaft bore, and the rocker skates on the plate quite nicely with two handed operation. The oil squirted into the bore of the rocker provides a small vacuum and significantly helps to keep the rocker 'planted' on its end, as it glides across the dance floor. I carefully lapped one end of each rocker to ensure no raised areas.
Two handed operation allows me to grind the full radius in one pass. The rocker starts is grind in front of the grinding wheel and moves around to the side of the wheel.
It was quite easy to develop a grind technique that provided a consistent pressure and travel speed. One of my old rockers was the dummy.
The grinding wheel is a basic 6" fine wheel.
Grinding the lobes? was a quick procedure with all four done in about fifteen minutes. Two or three light passes was sufficient with minimal removal of precious metal. Then I needed to deburr them and polish.
Hot off the press. The ground surface was better than appears in the photo. Radius surfaces are difficult to photograph!
![Image](http://i277.photobucket.com/albums/kk42/jeffr100rs/DSCN1633.jpg)
Course black, to maroon, to green scotchbrite did the rest.
![Image](http://i277.photobucket.com/albums/kk42/jeffr100rs/rocker%20lobe.jpg)
