Funny you should mention that Steve. It got whacked.SteveD wrote: Shouldn't you just whack it back to horizontal?
It was the only way to unscrew the relief valve.
When it was bent, the valve would foul on the bearing carrier when unscrewed.
It got a few cold whacks from above with a heavy hammer and length of timber.
I was concerned about fracturing the bearing carrier, or pulling the metal threaded relief valve straight out of the bearing carrier. Heating to bend would have been best I spose with the correct oxy-acet welding tip, but I no longer have it in my shed.
Anyway, neither catastrophe happened and out came the valve.
