I've seen a couple of videos on youtube. It looks like you twist the coil rubber cap and twist the spark plug wire while pulling both.
I tried that and I could not remove either left or right spark plug wire from the coil.
I can pull harder. But I don't want the pull off the soldered on end piece (under the coil rubber cap that is inserted into the coil).
Suggestions?
1982 BMW R100RT - Difficulty removing Spark Plug Wires from Coils.
gsm_r100rt
Re: 1982 BMW R100RT - Difficulty removing Spark Plug Wires from Coils.
There may be some corrosion. I'd peel back the rubber and squirt in some WD-40 then let it soak.
