Toaster tank
Mal S7
Toaster tank
Post by Mal S7 »
What's the differences between the toaster tank and the tanks without the chrome side panels?
I know they have side-tabs, and screw holes to hold the badges and panels. In photos it also looks like they have an outline groove in the shape of the panel, or is the whole side area a slight depression?
I got a rush of blood last night and bid on a couple of panels. Now I am not sure what I will actually do if I win 'em.
cheers
Mal
Re: Toaster tank
I have an article on the various tanks. The toaster tank is the same as if it didn't have the panels. They just didn't weld on the tabs that the chrome hooks behind.
Re: Toaster tank
Post by Garnet »
There may be some info here: http://boxerworks.com/forum2/viewtopic. ... aster+tank
If your tank has the two little straps to hold the back of the pannels in place they should fit.
Mal S7
Re: Toaster tank
Post by Mal S7 »
Thanks Duane, Garnet, thats great news.
If they are much the same I am sure I can work out a way to attach them if I win.
That will tart up the /7.
Gaudy 70's americana, don'tcha love it!
Deleted User 62
Re: Toaster tank
Post by Deleted User 62 »
Mal S7 wrote:Thanks Duane, Garnet, thats great news.
I've thought about going the same route, but using magnets glued to the covers and maybe a dab or two of Goop fore and aft to preclude movement.
Re: Toaster tank
Post by Garnet »
Did the later small tanks have screw holes for the emblems?
Deleted User 62
Re: Toaster tank
Garnet wrote:Did the later small tanks have screw holes for the emblems?
Nope, but a glue on emblem will fit.
Mal S7
Re: Toaster tank
Post by Mal S7 »
I like your thinking Tim. Maybe that material they use for magnetic signs?
I think the rear tabs could be epoxied on, epoxy these days, given a clean surface and enough area is mighty strong.
Deleted User 62
Re: Toaster tank
I don't think the magnetic strips sold for signage are strong enough. I was thinking of some 15mm disc magnets glued inside each corner of the panel, using something like Household Goop, a very strong, but removable silicone glue. Then the panels can be positioned and a smaller dab of the same glue between magnet and tank would preclude movement. This would eliminate the possibility of being peeled off by the wind or when getting bumped around, but they would still be easily removable.
Re: Toaster tank
I'm not sure of the look of the chrome panels on a /7 tank?
