I had the wheel bearings installed by my local BMW guy. I didn't want to make a potentially expensive mistake by doing it my first time on good parts.
But it appears that the hub i had laced is different then my spare /5 hub and perhaps some parts are missing.
The clean one is intended for the bike I am building.
The dirty one has been my placeholder.
The dirty one has a rubber seal and a top-hat like spacer which pops out of the axle hole just a bit.
The clean hub has a different sized area so the same rubber seal would not fit there.
on the Fiche it says a felt ring is needed and then a ring cover for up to 73.
After 73 there is the rubber seal.
So does that small top-hat spacer get used with my clean hub?
And where does the felt ring go and how does the ring cover secure it?
does anybody have a photo of what it should look like?
Thanks in advance.
![Image](http://i100.photobucket.com/albums/m23/josh_Withers/photo.jpg)
![Image](http://i100.photobucket.com/albums/m23/josh_Withers/photo-3.jpg)
