Rear brake o-rings
hzbloke
Rear brake o-rings
Post by hzbloke »
I was chasing a leak in the rear drive of my '86 R65 (it turns out it may have just been a weeping fill-level plug) and so ordered the various seals/gaskets/o-rings. The o-rings on the rear brake cam (21) were standard looking ones that fit in a groove. The ones that were sent are very thin and larger diameter. Looking at the fiche I came across this (item 20):
There are two item 20s listed.
20 O-ring 10X2 2 07119906328 $0.13
20 Gasket ring 12X1 2 35211457605 $1.32
The o-rings on the shaft (21) were definitely the 10x2 and there were no others. Does anyone know anything about the 12x1 'gasket rings' . Are they an alternative to the o-rings or should they all be fitted and, if so, where? Motobins only list the 12x1 as being for my bike.
Cheers
Ray
1986 BMW R65
2008 Moto Guzzi Breva 750
2019 Kawasaki Z900rs
montmil
Re: Rear brake o-rings
Post by montmil »
Both my 1981 and 1983 R65s have a felt "gasket ring" which is most likely the 12x1 item.
BMW mothership expects the felt to absorb the final drive lube that always seems to find a way out. :roll:
1981 R65
1983 R65
1978 R100S
1995 Triumph Trophy
Ray from Indiana
Post by Ray from Indiana »
Harbor freight sell a box of o-ring assortment made of nitril rubber. Part of that assortment is 10qty 9.8 x 2.4 rings. You can make them fit
Leaks there usually caused by overfilling
hzbloke
Post by hzbloke »
Number 18 in the diagram is the felt 'gasket ring' (19 is a washer). I have one on mine too, on the right-hand outside of the final drive under the brake lever. The o-ring that puzzles me is very thin (1mm) and the same diameter as the shaft (12mm).
I picked up some 10x2 o-rings from a local car parts shop. Thanks for the suggestion about the Harbor Freight assortment but their nearest store is a fair way from here.
1986 BMW R65
