New Guy with a Project bike.
- ChuckyShamrok
Re: New Guy with a Project bike.
Quick update so you now I ain't blowing you off. I got a working test light now! WOO, but I haven't touched the bike at all. Life has gotten in the way. You know how Job Searching, chasing girls and it being BLOODY COLD OUT is.
I smoke my last cigarette and swear to god it's been fun.
- ChuckyShamrok
Ok, Update time! Set the points using the test light, got them to open at the S mark, still won't fire. With the ignition on and cranking the bike over, I have pretty good suction on the exhaust pipes, like, will leave a ring on my hand.
Sounds like the valve timing is out.
- Ken in Oklahoma
Ignition on, but did you lay the plugs on top of the head to see if they're firing? If so then squirt a bit of gas into one cylinder, put the plug back in, and see if it fires for a few revolutions.ChuckyShamrok wrote:Ok, Update time! Set the points using the test light, got them to open at the S mark, still won't fire. With the ignition on and cranking the bike over, I have pretty good suction on the exhaust pipes, like, will leave a ring on my hand.
I did pick up one thing in all the conversation. The plug wires should have a 1K ohm resistive cap not a 5K ohm one.
One thing I have done to hold the advance in the advanced position when I was adjusting the points was to make a washer to hold that portion in the advanced position and then used the center bolt to keep all the parts in that position. Still don't see what is accomplished with that info, I have always set the indicator to the fire position and adjusted the points to just start to open statically.
1974 R90/6 built 9/73
1987 BMW K75S
1994 BMW R1100RS
1964 T100SR Triumph
1986 Honda XL600R
1987 BMW K75S
1994 BMW R1100RS
1964 T100SR Triumph
1986 Honda XL600R
- Ken in Oklahoma
It doesn't matter. The purpose of 1K or 5K resistive caps or resistive spark plug wire or resistor plugs is to be kind to your neighbor, radio interference wise. Those of us who are old enough to have ridden in a car with the radio on an AM station will remember the popping that happened when getting close to some cars. That popping was radio frequency interference caused by the spark jumping the plug gap. That spark releases energy across a broad frequency spectrum (including the AM radio band). FM radio, by virtue of frequency modulation is unaffected. AM, or amplitude modulated radios can and do receive the interference.jagarra wrote:I did pick up one thing in all the conversation. The plug wires should have a 1K ohm resistive cap not a 5K ohm one.
- enigmaT120
I wish we could do that to cell reception.Ken in Oklahoma wrote:It doesn't matter. The purpose of 1K or 5K resistive caps or resistive spark plug wire or resistor plugs is to be kind to your neighbor, radio interference wise. Those of us who are old enough to have ridden in a car with the radio on an AM station will remember the popping that happened when getting close to some cars. That popping was radio frequency interference caused by the spark jumping the plug gap. That spark releases energy across a broad frequency spectrum (including the AM radio band). FM radio, by virtue of frequency modulation is unaffected. AM, or amplitude modulated radios can and do receive the interference.jagarra wrote:I did pick up one thing in all the conversation. The plug wires should have a 1K ohm resistive cap not a 5K ohm one.
Ed Miller
'81 R65
'70 Bonneville
Falls City, OR
'81 R65
'70 Bonneville
Falls City, OR
Ken, if your bike had a digital electronic ignition, then you should fit 5K ohm resistance or there is a chance that your electronics might get blown. Being nice to neighbors is a good thing so I would fit 1K OMH caps on a points equipped bike.Ken in Oklahoma wrote:It doesn't matter. The purpose of 1K or 5K resistive caps or resistive spark plug wire or resistor plugs is to be kind to your neighbor, radio interference wise. Those of us who are old enough to have ridden in a car with the radio on an AM station will remember the popping that happened when getting close to some cars. That popping was radio frequency interference caused by the spark jumping the plug gap. That spark releases energy across a broad frequency spectrum (including the AM radio band). FM radio, by virtue of frequency modulation is unaffected. AM, or amplitude modulated radios can and do receive the interference.jagarra wrote:I did pick up one thing in all the conversation. The plug wires should have a 1K ohm resistive cap not a 5K ohm one.
I'm not sure the exhaust pipe is the best way to check engine timing,I would pull a carb off and put your hand over the intake while cranking, it should create a fairly large suction... about enough to suck a small cat off the street. If there is none, or it creates pressure, you've got a basic engine timing problem, or tight valve, something basic.ChuckyShamrok wrote: With the ignition on and cranking the bike over, I have pretty good suction on the exhaust pipes,
- Ken in Oklahoma
I'm not sure I understand what you're saying. What I'm trying to say is that an airhead will run just fine with 0K, 1K, or 5K resistance whether wires, caps or plugs. Personally I want to be kind to my neighbors so I run with 5K resistance. But I don't have a digital electronic ignition nor does any stock ignition airhead. Am I missing something?chasbmw wrote: Ken, if your bike had a digital electronic ignition, then you should fit 5K ohm resistance or there is a chance that your electronics might get blown. Being nice to neighbors is a good thing so I would fit 1K OMH caps on a points equipped bike.
I can imagine that if I were to install a digital electronic ignition, the design might require me to fit 1K caps. And I presume that the instructions that came with the ignition would point that out. Is that your point, reminding me (and others) that some aftermarket ignitions are different? I'm not trying to be cute here. Just to understand the concern.
