There are only so much you can hook to the battery terminals.ME 109 wrote: ↑Sat Nov 11, 2017 6:55 pmMy Oxford grips are wired straight to the battery. The Oxford system relies on a charging signal from the battery, so if the bike is not running there is no 'signal' and the grips will turn themselves off after two minutes. I can't recall if there is a relay or not. I'll check it out later.
switched circuit
Re: switched circuit
I found that to be the case. That is why I found a suitable fuse block and ran one fat wire from it to the battery.Zombie Master wrote: ↑Mon Nov 13, 2017 11:10 pm There are only so much you can hook to the battery terminals.
(I made sure there was no ground in the box. I used nylon fasteners to hold the accessory pod to the frame.)
When I sold the R65, it was in pieces, and I kept a few things, the fuse block and the Fiamms included. They finally both came in handy on the CBR250R.
(I won't buy another aftermarket alarm for a bike)
The horn connection is not identified in the image. I never did get heated grips on the CBR. Didn't need them, I had muffs.
My Motobatt has dual pos and neg outlets. Led lights and heated grips are connected to the 'extra' terminals.Zombie Master wrote: ↑Mon Nov 13, 2017 11:10 pmThere are only so much you can hook to the battery terminals.ME 109 wrote: ↑Sat Nov 11, 2017 6:55 pmMy Oxford grips are wired straight to the battery. The Oxford system relies on a charging signal from the battery, so if the bike is not running there is no 'signal' and the grips will turn themselves off after two minutes. I can't recall if there is a relay or not. I'll check it out later.
But, as Rob showed earlier a power outlet up front would be good too.
You dont need or want to use the extra battery earth on the four post Motobatt - DAHIK '
Just clean up one of the fender bolts if you need an earth close.
EME has good prices on most loom parts-----------.
I used this system on my Suzuki, but I only need to add heated grips to the R100 and would rather not add a bunch of wiring.
https://www.easternbeaver.com/Main/Wiri ... ealed.html
