Wow! I wasn't expecting so many responses!
Rob wrote: ↑Wed Apr 21, 2021 2:38 pm
You probably had one petcock on, and one off, but the crossover wasn't sufficient to feed both carburetors, which probably need some cleaning, no doubt.
Absolutely was running one on one off. I figure that's why at higher load/RPM, the fuel flow from a single petcock wasn't sufficient. It's also equally likely that perhaps it's in need of cleaning and/or the tubing may be semi-clogged?
I also recommend you empty the fuel tank and flush it, if you haven't already. Get any water out that might be in there.
Yep. This is on the agenda for next week I hope.
The stock charging system is just adequate on a good day. If it has a lead-acid battery, consider upgrading to a sealed unit. I'm sure the guys can recommend a current model. I don't remember which one I had (black w/orange top). I bought it, and never bought another until the day I parted out the bike.
It's got an AGM sealed in it now. Bought it about a month ago.
Steve in Golden wrote: ↑Wed Apr 21, 2021 3:29 pm
Occam's razor strikes again!
Welcome to the forum kmisterk!
Photos, we need photos of the bike pls
Haha, you're not wrong. The simplest solution often is the correct solution. And thank you! I am super happy I found this place. Photos will absolutely be coming soon, as soon as I manage to remember to take pictures of it
Like, good ones. Every time I say that I want to, I get to the bike, and all I wanna do is ride it lol. C'est la vie. SOon, though, I promise!
melville wrote: ↑Wed Apr 21, 2021 3:31 pm
Welcome to the board! So happy for simple solutions.
Thank you! And yes, thank god! I was like, in the process of mentally preparing for a weekend discovery-and-repair session! Maybe next year
Rob wrote: ↑Thu Apr 22, 2021 9:31 am
Petcocks can be rebuilt.
You will want to drain the tank so that you can drop both petcocks and check for debris and make sure that the screens that go over the outlet tubes are in place and looking good.
Noted! Based on what I've seen so far, and from what the local shop mentioned when I took it to get new tires (yeah, I'll do it myself next time, don't you worry), the bike has been exceedingly well-maintained. However, this is easy maintenance, considering how easy it is to actually get the tank off.
gspd wrote: ↑Thu Apr 22, 2021 12:38 pm
On a stock system, if everything is flowing properly, either tap will feed both carbs simultaneously without concern.
And for the most part, the bike worked fine under light load at low RPM's. When the gas needed to flow, though, such as at higher RPM's, it started to bog.
It's a good idea to slowly rotate each fuel tap lever a few full turns occasionally so the gas can lubricate their internal seal(s) and keep them working smoothly. If they are really stiff, wiggle them back and forth until they can freely be rotated 360 degrees.
I would strongly recommend checking your float bowls for water and debris immediately,
and then again at regular (monthly?) intervals.
Good tip about lubing it up with the rotation trick. Definitely an easy maintenance action. Why the worry about the Float Bowls? Does running off of a single petcock cause any different behavior than both open, or is it just generally good practice to check them for water/debris anyway? It has an in-line fuel filter on both sides, so I'd wager it'd be quite difficult for large debree to get in there, unless through the air filter and passing in through the carb, somehow?
Not a terrible idea, in any case, and I most certainly will take the the time soon to check out the float bowls in pursuit of good maintenance practice.
