gspd wrote: ↑Mon Aug 23, 2021 7:16 pm
If it always starts perfectly with
literally only two seconds of cranking (as it should), your starter is probably OK, although it can't hurt to disassemble, clean and lube it when you have some spare time.
Even on a cold start with the enricher enabled, under what I've come to experience with this bike as being "normal," I never have the starter motor running for more than 2 seconds to get the bike going. Unless, of course, I forget to toggle back on the petcocks, but then it kicks on right away after I rectify my own mistake there. When riding it consistently throughout any given time period, the motor
usually kicks on after only one or two cranks of the engine.
Cranking the starter for inappropriately long periods of time should simply run down the battery and NEVER melt the terminal(s), as anyone living in a cold climate with an old car can attest.
Yeah, I was particularly concerned with how it wasn't starting. With such a simple level of complexity, this should have been a warning to me to check other things before just blindly trying to continue to start the motor.
What misled me is
where your battery post melted. Usually, the actual loose contact point is exactly where the arcing and melting will occur. I suspect your battery possibly had a flawed (cracked?) terminal. The type of meltdown you experienced is usually only caused by a solid direct short of the battery. The terminal is designed to melt under a solid short circuit, sort of a fusible link, rather than exploding the sides out of the battery.
Yeah, my mechanic brother said he'd never seen the terminals melt off a battery like that before, and also mentioned it would need to be a
short, specifically and not just a loose connection. But I guess, running high amperage for extended periods of time through poorly connected electrical connections can also generate quite a bit of heat. It even managed to melt a hole through the bottom of the under-seat toolbox.
When car batteries become solidly shorted (by the hood for instance) as in some collision situations, the actual terminals will melt before the battery explodes. I've seen that happen a few times, but never on a motorcycle.
Whelp, at least you can now say you are aware of at least one motorcycle battery having a terminal melt off.
bows not-so-gracefully
