'84 R80RT Idle Drop
dwerbil
Moderator
Re: '84 R80RT Idle Drop
Post by dwerbil »
Native /5 wrote: My '77 R100 was stalling coming off high rpms to idle. I found the valves to be too tight and loosened them to spec. Idles fine now. FWIW
That's come up a few times over the years with my '84RS and /7.
Use as a matra....Om-m-m....when-idle-is-goofy-check-valve-settings....Om-m-m-m....
Click for pics
Randy in Round Rock
05hexhead
Re: '84 R80RT Idle Drop ++SOLVED++
Post by 05hexhead »
I tried new O-rings and setting richer mixture settings and it did not improve the idle drop.
But all the messing with the mixture and throttle stop settings I decided to set up my balancer and check out the sync. What I noticed was when then balancer was hooked up there was no fluctuation in the RPM's, it was rock solid and no dip return from high RPM's.
I had just bought this bike and it was just covered in oil so when I was cleaning it up I decided to remove the Pulse Air system. I bought the R1100 drain plugs for the heads, flywheel inspection plugs for the air box and hunted down the appropriate screws for the carb balance ports. Being anal I put some nitrile O-rings on these screws. Wrong! Removed the o-ring and the screws are sealing fine.
Man are the 800's ever smooth.
Thanks for all the suggestions.
Nick
'05 R1200RT
'95 R100R Classic
'84 R80RT naked
'94 R100GSPD sold
'84 R100S (wannabe) sold
'97 R1100RSL sold
'81 R100 sold
Native/5: The carbs that came on the '71 R75/5 when I got it were 64/32/3 & 4.
I don't know when (month or year) they changed "officially".
