Re: Flat to round air filter conversion
Posted: Fri Mar 23, 2012 5:26 pm
Don't fret jeff. Bit o' dust n insects in there is good, keeps them moving parts nicely bedded for more performance. Don't let 'em tell you otherwise.
Boxerworks Member Forum
https://forum.boxerworks.com/
And despite that, I use one.Major Softie wrote:SteveD, that page is great. It certainly makes it clear why K&N's are popular: they flow more air. Thus, K&N's are the most likely filter to require jetting changes. It also makes it very clear HOW the K&N flows more air: by letting in a lot more dirt.
We've speculated here in past discussions that the K&N may well do a decent job of filtering after it has gotten dirty. The tests prove the complete opposite. That was the most surprising part to me.SteveD wrote: And despite that, I use one.![]()
I've had it for years, and periodically I remove it for a pleated paper filter, but it went back in when I fitted the less restrictive Jim Cray mufflers. It rarely gets washed, but is regularly inspected to have anything solid removed, eg insects, and it'll then get a spray of the prescribed filter oil. In all that time the inside of the airbox has remained remarkedly clean. A finger swipe over the surface only ever reveals a very slight film of oil from the breather. It's also had the modification at the front so that it seats and seals correctly.
The tests certainly show increased flow of dirt. Many have therefore suggested engine longevity would be shortened. As a piece of research it seems ok, (the purolator wasn't sealed correctly though) but there are limitations to the conclusions that may be drawn.Major Softie wrote:We've speculated here in past discussions that the K&N may well do a decent job of filtering after it has gotten dirty. The tests prove the complete opposite. That was the most surprising part to me.SteveD wrote: And despite that, I use one.![]()
K&N are oiled cloth, not foam. The Uni-filters we were also talking about are foam.KenHawk wrote:Theres simply no way I'm going to invest big $$$$ into my engine and then install a K+N foam non-filter. I might be crazy but...
