Major Softie wrote:You looked inside them?!!!
I feel a need to come to Charlies aid here as he never said he looked inside, technically speaking.
Phew, thanks for the support, Jeff. This sure is a tricky place when it comes to technical matters like this. It is so easy to be misconstrued, misquoted and generally misunderstood.ME 109 wrote:Major Softie wrote:You looked inside them?!!!
Chuey,Chuey wrote: The light fixture I chose for the tail light may not be a good long term set up. It comes from a Moto Cross oriented company called Acerbis. The plastic housing is so close to the bulb that it is melting the housing.
I am SO relieved!Airbear wrote:Phew, thanks for the support, Jeff. This sure is a tricky place when it comes to technical matters like this. It is so easy to be misconstrued, misquoted and generally misunderstood.ME 109 wrote:Major Softie wrote:You looked inside them?!!!
Look under the dash of any modern car for just a few minutes; your bike's headlight guts will no longer look scary.ME 109 wrote:One look in the headlight bucket was enough for me. That's some scary sh!t in there.
gspd wrote:Look under the dash of any modern car for just a few minutes; your bike's headlight guts will no longer look scary.
A car salesman's dream customer!ME 109 wrote: I didn't even lift the hood, what the hell was I going to find! I knew there was a motor in there.
I won't go looking under the dash.
gspd wrote:A car salesman's dream customer!
You can tell a lot from looking under the hood;
Especially if there was a previous front end collision.
What are you lining, the brake light? Keep in mind that this will act as heat insulation, and will thus make any overheating of the base worse. Of course, an LED taillight bulb will help to alleviate that; they do not run truly "cold," as Rob put it, but they do not create anywhere near as much heat as incandescents.Chuey wrote:Thanks to Rob Frankham for the great tip. I think I'll do just that. It seems obvious but it wasn't coming to me. The other thing I think I'll do is to line the (black) housing with aluminum foil so it reflects a little of the light back to where it is supposed to be.
