LED spot light.
Re: LED spot light.
Sibbo wrote:
Seth wrote:Just make sure you look at the beam width. The ones identified above are floods with a broad but not long beam. The spots have an 8 degree beam for a much longer reach.
I want a light the lights the road verges and shows the wallabies and roos waiting in ambush .
Flood on the left, spot on the right?
I agree, the wider flood light is much more important than the narrow distant spot.
Re: LED spot light.
Sibbo, you probably remember this thread - you started it in 2010 -
viewtopic.php?f=17&t=764
You'll recall I fitted the LEDs in question, and am still very pleased with them ...
Here is low beam (50W) …
… and high beam (75W) alone …
… and high beam plus spotlights.
However, good as they are for riding at moderate speed in the twisties, and seeing critters on the side of the road, I still don't have enough light out the front. I need something that will penetrate. I want to be able to see that mob of pissed 'roos lurking around in their camo gear a few hundred metres ahead when I'm travelling at speed on a straight road. For this, I think a bright spot with a narrow beam, say 10 to 20 degrees, would work. I like the look of these -
http://www.ebay.com/itm/121117952013?tf ... lgo=origal
I'd really like to see them in action. A combination of spot and flood is the way to go, IMO.
Sibbo
Re: LED spot light.
Post by Sibbo »
The two together sounds like a good idea Charlie, the Jaycar spot is 2.4 amps versus the US Ebay one at 1.67amps . The extra could be worthwhile if we can run it. What do you think?
The prices would be about the same after post and the $ rate exchange .
Specifications http://www.jaycar.com.au/productView.asp?ID=SL3919
• Beam pattern: Flood (SL-3918), Spot (SL-3919)
• Beam distance: Flood 183m, Spot 378m
• Lumen output: 3486
• Equivalent halogen lamp: 300W
• Input current: 2.4A (12Vdc), 1.2A (24Vdc)
• Operating temp: -40ºC ~ 60ºC
• Dimensions (mounted): 120(Dia.) x 82(D)mm (excluding bracket)
US ebay.
Light Source:2pcs 10w CREE LEDs
Power Consumption:20W
Lumens Output :2000LM
Operating Voltage:9-48V DC
Amp Draw (12V DC):1.67A
Dust and Waterproof:IP68
Color Temperature:6000K
Body Material:Extruded 6061 aluminum housing
Lens material:PC
Mounting Bracket:Stainless Steel
Beam Angle:Pencil beam(20 degree)
Optional Beam:Flood beam(40 degree), tell us if you need
Lifespan:50000 hours above life time
There are some good looking lights on that Ebay page.
The Grateful Dead
Re: LED spot light.
I picked up this mofo from the disposals store. The bloke reckons I only need one on the RS.
I dunno, but I reckon I'd need one on the other crash bar as well.
Would an enduralst alternator be better than the one from motolectrics or will the oe be fine?
Re: LED spot light.
Peter, I wouldn't worry too much about whether the bike's electrics can handle the current draw for any of the LED auxiliary lights. The Jaycar, at 2.4 Amps, is only 29 Watts. The US ebay one is only a couple of watts more than one turn signal bulb. Bugger all, really.
I had a look at the Jaycar version in the flesh a couple of weeks ago - it is big - too big for my liking. They only had the flood type at the time, so I couldn't see the spot in operation. The size of it put me off anyway.
The thing about the US ebay version is that there are two of them. If one gives enough light, then the other can be passed on to somebody else, or if required and possible, mount both to give a huge amount of light. I only use the LEDs for high beam work and there is the option of disconnecting the main headlight high beam but keep the low beam. The existing headlight is a pretty dim yellow. Puts out lots of heat, but the beam kind of droops onto the road, reminding me of my 6 Volt VeeDub days.
Re: LED spot light.
ME 109 wrote:I picked up this mofo from the disposals store. The bloke reckons I only need one on the RS.
I reckon you'll need one each side to stay balanced, Jeff. Symmetry is good. And you'll prolly need to pull a trailer with a fekkin' big diesel generator to power them. At least I might be able to keep up with you then.
Sibbo
Re: LED spot light.
Post by Sibbo »
Airbear wrote:Peter, I wouldn't worry too much about whether the bike's electrics can handle the current draw for any of the LED auxiliary lights. The Jaycar, at 2.4 Amps, is only 29 Watts. The US ebay one is only a couple of watts more than one turn signal bulb. Bugger all, really.
Thanks Charlie, anything with wires coming out of it is something of a mystery to me but being able to turn off the high beam seems like A REALLY good idea , mine is OK if I travel slowly and I do because of the not quite enough kind of light, much better than my old trail bike days but still lots of heat and not enough light.
I'll go up to Jaycar next Tuesday and see how big their offering is, there are no dimensions on the page .
The Grateful Dead
Re: LED spot light.
Peter, you posted the dims - "Dimensions (mounted): 120(Dia.) x 82(D)mm (excluding bracket)"
The US ebay offering is almost as wide, but only half as high.
Ask the Jaycar salesthing to hook both the flood and the spot up to a 12V supply so you can see the brightness and pattern.
Sibbo
Re: LED spot light.
Post by Sibbo »
You're right, I must be going blind or something . I probably won't get much of an idea of the pattern in daytime or in the shop .
The US Ebay version is a spot but we'd both like a combination of a spot and a wider beam. I'll email the seller and ask if that is a possible sale.
I found the same lights on Oz Ebay.
The Grateful Dead
Toga
Re: LED spot light.
Post by Toga »
Almost all those appear to be available in a range of beem pattern, the only difference being the lense.
If your interested in the 2x20w unit ie: 4 globes, then perhaps you could buy the 8 degree beem spots and replace only 2 lense's with 30 or 60 degree ones... giving you both a spot beem and a wide beem... doesnt hurt to ask them ?
