One (maybe the only one? no, there's others) benefit of having the master cyl for the front brakes under the tank is you need to pull the tank often to service the ms then you'd notice a problem with the gas lines, etc pretty quick.
(Another is in the case of some discrepancy as to which side should the rubber be on relative to the bike/road it doesn't get smashed.)
1986 R80 - Tank Vent Doing It's Job?
Re: 1986 R80 - Tank Vent Doing It's Job?
Re: 1986 R80 Naked Bike - Tank Vent Doing It's Job?
I assume you mean the "pulse air" system? Snowbum did a good write up on it here: http://bmwmotorcycletech.info/pulseair.htm Note: the wiring subharness can be eliminated by unplugging both ends and connecting the male to female plugs from the main harness together.captmako wrote:I'm also going to remove the shed fuel system. Any good tech tip links on removing the shed fuel system? I searched
and found nothing right on point. Thanks all.
Tim, thanks for the link. Snowbum calls it the "Evaporative Emission System." Prior owner removed disconnected the
tank overflow hose from the system. I'm going to remove the cans and plumbing that remain and reroute the 2 tank
hoses. Should be good to go afterwards. Thanks.
I haven't used a hose for the tank overflow for years and years. Do most use this hose?
I'm with you Steve - never had a hose on there, never had petrol come out of the 'overflow'. Isn't that sealed off from the tank when the cap is on?
1986 BMW R65
2008 Moto Guzzi Breva 750
2019 Kawasaki Z900rs
