Re: starting problems
Posted: Mon Mar 10, 2014 10:21 pm
It really sounds like a lean mixture.
Stop messing around, do the simple test suggested by Ken. Remove the plugs and drip in a few drops of fuel. Replace the plug and don't open the throttle very much. If it fires a few times and quits, then that is a strong indication that it is running lean. Repeat with a bit more fuel. Then it should run a bit longer and probably quit. However, you may have it warmed up just enough to be able to keep it running.
What result do you get with measuring compression? Where did you see the timing mark on the flywheel?
This stuff is just plain logical and if one follows the trail, all will fall into place.
Back in about 1968 I needed to hear an engine run. It had some mixture problems and I tried the usual stuff. I ended up removing the air intake tube and squirting fuel into the intake from a squirt bottle. It worked and I was able to ride it a couple of blocks with my right hand on the throttle and my left holding the squirt bottle to allow in a bit of fuel. I had to tape up my left pant leg to keep it from getting sucked into the intake.
I don't recommend that procedure.
