Re: Cutting down the RS windscreen
Posted: Sun May 04, 2014 10:06 pm
The parabellum has a duct cut front lower centre. There are a variety of ways to add a duct. I have no idea which is best as shape and position varies. A true naca duct would be a little tricky to do well.tsa wrote:One reason you may experience buffeting behind the RS screen, could be the relatively lower air pressure that builds up behind the fairing at speed, which IMHE tends to distort the laminar airflow above the screen into a turbulent slipstream that may hit the base of your helmet. As an experiment, I just removed the parking light assembly - to allow air getting into this low-pressure area - and it seemed to reduce the buffeting I experienced. Perhaps worth trying, since it doesn't involve cutting off bits that cannot be put back onto the screen again.
