Re: How to lower front fork height?
Posted: Sat Jun 28, 2014 5:22 am
Depends how much you need to lower it but If not too much I'd start from first principles and measure laden sag to make sure the suspension is correct for your wife's weight. If there is not the desired 30-33% laden sag on the forks you have potential right there to lower the front end by removing pre-load spacers or lowering the spring rate and you would be keeping within design intent by doing this. Same goes for the rear suspension but once you are on the lowest pre-load setting the only option is softer springs. Be careful about using shorter stiffer springs as that might lower unladen ride height but not laden ride height. I'm assuming there one of the issues is getting feet down when the bike is stopped at lights and junctions.
However a lower suspension ride height is achieved it's going to make the bike more of a pig to put on the centre stand so you may want factor a mod in for that.
Failing all that early R65's have the lowest seat height of any of the contemporary Airheads.
