I used the word triumph, not Triumph. I wouldn't wish a Triumph on anyone, but I do hope that we all have a triumph from time to time.
But you knew that. Guess we ran out of ways to degrade a thread.
completely baffled
Re: completely baffled
- enigmaT120
Hey, you have one too? But the sex is totally worth it.Pattern14 wrote:British bikes are a case of blind perseverance in the face of staggering reality.
96,000 miles on my '70 Bonneville.
Ed Miller
'81 R65
'70 Bonneville
Falls City, OR
'81 R65
'70 Bonneville
Falls City, OR
Very Good Duane,Duane Ausherman wrote:I used the word triumph, not Triumph. I wouldn't wish a Triumph on anyone, but I do hope that we all have a triumph from time to time.
Sorry to hear your distaste for trumpets. I will always have a soft spot for them. After all, whitworth tools have to serve SOME purpose.
AMA Charter Life Member
Rebel said, "After all, Whitworth tools have to serve SOME purpose.
This takes me back. Some 35 years ago I had quite a bit of Whitworth tools etc. My solution was to give them away to a friend who had some Brit iron. He still does, stuff that doesn't run. I only had one condition. He had to never give them back to me. It was a one way gift.
Now he has those things made in India. They don't run, so I asked why he didn't get a BMW. He used to have them and his father only rode BMW, so he grew up around them. His answer, "They cost too much."
One can spend some money and have nothing, or spend more and have something. I never understood those who chose the former option.
No BMW has ever cost me a cent. I have come out even on a few, but way ahead on most, as that is how I made a living in the distant past. I call that something for nothing.
Thanks Duane, my vibration on my RS is taking me back to the T-140 days myself. I guess my idle adjust is out, but I have not built a jig to do the shorting method for adjustment. I am planning on making a jig from standard light switches with the coil feeding the switches, and one position of the switch feeding the plug and the other connected to chassis ground to protect my electronic ignition & coils. Hopefully at some point I will get the vibration under control on this bike.
The shorting method is fraught with problems. Do it by ear. Faster and better. One of several articles on this issue is http://www.w6rec.com/duane/bmw/carb/index.htm
You said, "Sorry to hear your distaste for trumpets."
I like both trumpets and coronets. I prefer the Saxophone though.
I had hot sax with a strumpet once. Does that count?
He confused you with a capitalization error. He meant "Trumpets."Duane Ausherman wrote:The shorting method is fraught with problems. Do it by ear. Faster and better. One of several articles on this issue is http://www.w6rec.com/duane/bmw/carb/index.htm
This thread has clearly turned and has nothing to do with the title which surly had something to do with making Harleys more quite.
1979 R65
1979 R65
PM me your address and I'll send you some cut down spokes so you can synchronize with the ShortMeister method. One piece per side, installs without tools. Pix and an explanation are found in my build thread.Rebel wrote:Thanks Duane, my vibration on my RS is taking me back to the T-140 days myself. I guess my idle adjust is out, but I have not built a jig to do the shorting method for adjustment. I am planning on making a jig from standard light switches with the coil feeding the switches, and one position of the switch feeding the plug and the other connected to chassis ground to protect my electronic ignition & coils. Hopefully at some point I will get the vibration under control on this bike.
