I'm just wanting switched fused circuits that will power heated grips, radar detector, and GPS. I will still run an SAE connector off the battery for charging and heated vest. The SAE connector is part of the Yuasa battery analyzer which is where the end of the connector is terminated when not being used for charging, powering heated clothing, or checking the charge of the battery. I thought the Yuasa battery analyzer is so cool and cheap I bought a few @ ten bucks each. they are a no brainer....which I find helpful.Major Softie wrote:ZM's right. If you really need/want all that, it's a cheap solution, and it's certainly convenient.
http://www.motorcycle-superstore.com/12 ... y-analyzer
