Re: Replacing large left seal in rear drive, '81 R100
Posted: Wed May 11, 2016 6:57 pm
You must remove the cover and gear to get to the seal. Otherwise you would ruin the edge that keeps it in place.
Boxerworks Member Forum
https://forum.boxerworks.com/
This is for a modern 1981 bike, Duane. The seal can be replaced without removing the cover.Duane Ausherman wrote:You must remove the cover and gear to get to the seal. Otherwise you would ruin the edge that keeps it in place.
How much thicker are the cardan gaskets vs. paper at the proper torque?Bamboo812 wrote:Modern cardan gaskets are thicker now than the original paper thin ones. Replacing it will most likely require re-shimming.
Good point and I was waiting for this answer. I've replaced several Cardan cover paper gaskets and just supposed I was as lucky as that blind hog who finally found an acorn.mattcfish wrote:How much thicker are the cardan gaskets vs. paper at the proper torque?Bamboo812 wrote:Modern cardan gaskets are thicker now than the original paper thin ones. Replacing it will most likely require re-shimming.
The shims only come in .05mm increments from 1.5mm up to 2.5mm on the Max BMW site.
It may be thicker out of the box, but If the cardan gasket is less than .05mm thicker at torque then it's a non-issue.
