Rob Needs a New Brain
Re: Rob Needs a New Transmission
Jean wrote:Hey Rob!!
Be careful which direction you "Drill the Plug".
With your luck, it's be 90-deg to the direction you want.
the oil will get out.
I could see Rob's drill bit breaking before it became a problem. ;)
We YO friends, Rob...
check oil-thread to see what to put IN the gearbox.
Post by Deleted User 287 »
I have drilled it for screws, I have pried the shit out of it, and I have applied heat to the boss - now what?
Maybe I'll sell it all & buy a Ninja 250R.
esman100
Post by esman100 »
Soak it overnight with PB Blaster penetrating oil. Are you using a slide hammer with a coarse sheet metal screw?
Jeff
Washougal, WA
'76 R90/6 "Eva"
'62 R60/2-R75/5 Conversion
penetrating oil in my input bearing???
I'll try the slide hammer, if I can find a bigger screw.
I am NOT putting any more money into this pit from hell. That includes a trip to the store for larger screws.
Look for me on eBay!
esman100
Post by esman100 »
Penetrating oil into the metal seal surface...
Jeff
Washougal, WA
'76 R90/6 "Eva"
esman100
Post by esman100 »
Don't give up on it Rob; maybe you should reread "Zen and the Art of Motorcycle Maintenance".
Jeff
Washougal, WA
'76 R90/6 "Eva"
Robert Valdez to the principal's office please. Valdez to the principal's office..............
justoneoftheguys wrote:I have drilled it for screws, I have pried the shit out of it, and I have applied heat to the boss - now what?
For the input shaft seal (with the shaft in place) I use a long sharpened thin flat blade screwdriver, with a piece of clear windshield washer tubing covering all but the tip.(you could use a piece of gas hose, etc.
Jam it in the old seal and pry it out.
gspd wrote:It's not open bloody heart surgery or rocket science.
As long as the old seal comes out without wrecking anything and the new seal goes in square and to the correct depth, all is good.
For the input shaft seal (with the shaft in place) I use long sharpened thin flat blade screwdriver, with a piece of clear windshield washer tubing covering all but the tip.(you could use a piece of gas hose, etc.
Jam it in the old seal and pry it out. :lol:
gspd wrote: For the input shaft seal (with the shaft in place) I use a long sharpened thin flat blade screwdriver, with a piece of clear windshield washer tubing covering all but the tip.(you could use a piece of gas hose, etc.
It's like Deja Vu all over again. :roll:
