UTT Master Cylinder pressure light
Re: UTT Master Cylinder pressure light
^^ No cold concrete floors in Sydney
Wobbly wrote: ↑Sun Dec 10, 2017 7:58 pmYou have simply misunderstood. The act of dispersing brake fluid does not require conscious activity by a human. The OP's master cylinder is UNDER the fuel tank where it cannot be observed. When those master cylinders leak, they dribble fluid all over the painted frame and a host of electrical harness connections. Wind (from riding the motorcycle) will then loft the fluid and coat the underside of the fuel tank "tunnel". This condition can exist for months and create quite a mess before the fuel tank is ever removed.Zombie Master wrote: ↑Sun Dec 03, 2017 5:38 pm There is no reason to get brake fluid on your paint. That is sloppy work.
That's the specific conditions under discussion here.
I rode an R90 for 11 years and never had a leak. But then I do silly things, like specificly following the BMW service manual. Safety before cosmetics.
Recently went to look at a blue/ silver '83 R100RS on CraigsList with original paint. In the photos it looked excellent. When I got there the paint was completely screwed up on the lower RH fairing panel, inside and outside ! When asked about it he said the handlebar master cylinder had cracked open (frozen ?) and leaked, while the bike was under a cover in the back yard. The brake fluid had eaten all the paint off.
Even with the best intentions "Poop Happens".
Under a cover in the back yard doesn't seem like "best intentions"
- Steve in Golden
It should be against the law to put an airhead "under a cover in the back yard."
His headlamp bulb was running on 8 volts for sure.
- dirtsurfer
Well I have removed the tank and found the master cylinder to be leaking onto paintwork on the frame. The underside of the tank looks ok. My local airhead part supplier (4000 kilometers away) has 2 ATE dual disc master cylinder overhaul kits one is listed as pattern.Wobbly wrote: ↑Sun Dec 10, 2017 7:58 pmYou have simply misunderstood. The act of dispersing brake fluid does not require conscious activity by a human. The OP's master cylinder is UNDER the fuel tank where it cannot be observed. When those master cylinders leak, they dribble fluid all over the painted frame and a host of electrical harness connections. Wind (from riding the motorcycle) will then loft the fluid and coat the underside of the fuel tank "tunnel". This condition can exist for months and create quite a mess before the fuel tank is ever removed.Zombie Master wrote: ↑Sun Dec 03, 2017 5:38 pm There is no reason to get brake fluid on your paint. That is sloppy work.
https://www2.munichmotorcycles.com.au/i ... =2a&page=3
Anyone know what pattern means?
Pattern usually means a reproduction in my understanding. I recently went through rebuilding two calipers, and purchased what was claimed to be superior to OEM parts. They didn't fit. It caused me time and money. I ordered the OEM parts, and everything went together without a hitch. I suggest everyone use OEM parts, yes you pay more, but we want to have them available. In the end they are the best deal....IMO
