Mornin Charlie, I've had my speedo apart earlier in the year and the PC looks the same as yours. It even has
the high beam/pin 8 area same as yours(unused).
So maybe all the PCs are the same, just different conections and coloured lenses.
Slash Six Instrument Pod Wiring
Bob Bennett
Re: Slash Six Instrument Pod Wiring
Regards, Bob
R80 RS
R80 RS
- Airbear
Ah, thanks Bob. So you think the wires just go to different pins?
Bob Bennett
Yes Charlie, The Instrument Pod Plug wires are just conected different to the loom, not the pins.
The end where you have labled, Indicator, is conected to, high beam, on mine, and change of lens.
So Your drawing could only need colour changes(both wire & lens) and relabeling to work on any model.
I think??
I think??
Regards, Bob
R80 RS
R80 RS
Slash Six Instrument Pod Wiring - Drawing
hey charlie,
i just sent you a request for a beautiful copy of the drawing
many thanks for the effort
jim
jim
ToasterTan
Pretty innovative solution. The bucket appears to be from a Chang Jiang and can be ordered direct from them (I used to own one).
http://chang-jiang.com/bmw/welcome.html
There also may be a US outlet for parts you could find with a little Googlebanging.
- Airbear
G'day TT, and welcome aboard. The bucket is indeed from a Chang Jiang. I recently lashed out $65 for another one and fitted a Speedhut GPS speedo - the Acewell shat itself. We are happier now.ToasterTan wrote:Pretty innovative solution. The bucket appears to be from a Chang Jiang and can be ordered direct from them (I used to own one).
ps: Rapide, the pod diagram is winging its way to your inbox.
