Page 3 of 3
Re: Throttle cable Replacement
Posted: Sun Dec 07, 2014 7:16 pm
by Rob
I like the idea of leaving the left side lock nut loose and adjusting that side while going down a lonely road. I don't know if it would stay in place without tightening it down. Duane?
Or get one of those over-size thumb wheel nuts and replace the lock nut with it?
Posted: Mon Dec 08, 2014 2:16 am
I don't leave it loose. I rotate the nut by hand and it never moves. If someone makes a thumb wheel, that is good too. It won't allow the rubber boot to be slid back down over the adjustment nut. Notice that very tight fit on the carb top? That is to seal air out from getting into the slide chamber. Often, the boot is gone and they run just fine, so they aren't necessary. I cut the part off that makes it tight. Now it still keep water out, but won't seal out the air, which doesn't matter. It keeps out water though.
Posted: Thu Dec 25, 2014 9:02 am
by Norm T R100T R1150RT
I took a box end 10 mm wrench, cut the handle to a nub, then slotted the box just enough to slip over the cable and leave it positioned on the locknut to do on-the-fly adjustments.
Posted: Fri Dec 26, 2014 7:08 pm
Norm T R100T R1150RT wrote:I took a box end 10 mm wrench, cut the handle to a nub, then slotted the box just enough to slip over the cable and leave it positioned on the locknut to do on-the-fly adjustments.
Great idea, thanks for sharing it. I like that one. Mine never came loose when I just tightened the nut by hand, but it easily could and most would want it a bit tighter than finger tight.
Posted: Sat Dec 27, 2014 2:12 am
Maybe, they were tighter than you thought Duane. Did
you tighten them, or did
Diane?
Lots of airhead mysteries are easily explained.
Posted: Sat Dec 27, 2014 2:48 am
Diane?
I suspect that she gets paid to grab nuts by hand and I doubt that she tightens up much at all, but of course I can't ask her.
