Speed / Revs
grant81rs
Re: Speed / Revs
Post by grant81rs »
Gidday,
BANG!! on the money Bob, identical symptoms... :o
So I wonder if the speedo springs can be repaired at all
Cheers, Grant
Gippsland - Australia
1978 R100RS
1981 R100RS
1994 K1100RS
2005 R1150gsa
Bob Bennett
Re: Speed / Revs
Post by Bob Bennett »
$$$$$s Grant
Instrument Tech should be able to re calibrate for you.
Regards
Regards, Bob
R80 RS
Re: Speed / Revs
Grant81rs wrote:At 110kph on the speedo, the GPS shows 112kph @4500rpms - is this normal or not??
Well that confirms the speedo isn't too bad, but the tacho is reading high.
Three things to contemplate Grant. Assess, repair or replace.
1. Substitute the parts to see if the problem replicates. We have the parts so doing that is easy enough. Just tedious. When we next catch up, I have a do-dad that measures rpm. We can compare real rpm to tacho reading.
2. If one of the instruments, speedo or tach then shows that it's kaput, I can take it to Otto @ Ringwood Instruments for assessment. He does Motometer, but I'm unsure what he charges. He should be able to do something as overall the things are grossly intact.
3. Save up for replacements. They're out there, but they're getting expensive, and second hand they might have similar problems.
grant81rs
Re: Speed / Revs
Post by grant81rs »
Gidday Steve,
We shall suss it out first and run a few tests.... This sounds good to me :)
many thanks
Cheers, Grant
1978 R100RS
1981 R100RS
1994 K1100RS
2005 R1150gsa
Re: Speed / Revs
grant81rs wrote:Gidday Steve,
many thanks
Or try what I do. Cuss it out first, and then run to the store and get a new one! :)
Re: Speed / Revs
I would check the tach against an electronic meter before I assumed, I went a bought a new on,e or had it worked on, just as you checked the speedometer against the GPS.
grant81rs
Re: Speed / Revs
Post by grant81rs »
Major Softie wrote:I would check the tach against an electronic meter before I assumed I went a bought a new one or had it worked on, just as you checked the speedometer against the GPS.
Gidday,
Thank our next plan of attack MS... Will let you know the result when it happens :)
Cheers, Grant
1978 R100RS
1981 R100RS
1994 K1100RS
2005 R1150gsa
Sibbo
Re: Speed / Revs
Post by Sibbo »
grant81rs wrote:Gidday,
When cruising at 110kph on the speedo, the 78 RS shows 4500rpms on the tacho, is this normal?
The numbers stamped on the final drive are 33/11
It has been a while since a rode one of these earlier bikes and I cannot remember what my 81 RS used to do :oops:
Any thoughts!!
That's about the revs/speed ratio I have on my ST , do you have the correct final drive ?
The Grateful Dead
Re: Speed / Revs
Post by Rob »
Also, the gear set in the final drive could have been changed, with no mention of it on the outside of the case.
Re: Speed / Revs
Rob wrote:Also, the gear set in the final drive could have been changed, with no mention of it on the outside of the case.
Exactly why I was saying not to assume the tach was off without checking it against another known good meter.
I suppose checking the turns ratio of the wheel to drive shaft would be a good thing to check to make sure the stamped ratio actually reflects what's inside the drive.
