Page 4 of 5
Re: Measuring a frame for straightness
Posted: Fri Aug 27, 2010 7:39 pm
by Deleted User 61
Yes, what you say makes sense.
But what I understand is, putting additional preload on the pushrod moves the lever further away from the ideal of being parallel to the transmission case.
I will keep playing with it.
Wouldn't I need to heat it up to bend it? And then, would I be changing it's temper and need to consider things de re metallica?
Things which I know nothing, by the way.
that was just a tap
Posted: Fri Aug 27, 2010 7:46 pm
by gspd
Heck, I can do that in a with a few hammers blows, it didn't even break or rip out the studs.
I doubt that bent your frame if that was the only impact you subjected the bike to.
Posted: Fri Aug 27, 2010 7:48 pm
by Deleted User 61
Both fork tubes were bent and the left leg reflector broke out.
Posted: Fri Aug 27, 2010 7:54 pm
by Deleted User 61
Someone asked about what parts I reused in the rebuild.
I replaced a 1980 engine with a 1981.
I removed the clutch carrier and installed my heavy flywheel so I could keep using my old transmission.
So everything on the back of the transmission should be the same. I used the same clutch parts as before.
The only differences now is that I have Nikasil jugs and larger valve heads.
Posted: Fri Aug 27, 2010 9:16 pm
by gspd
R65 Rob wrote: But what I understand is, putting additional preload on the pushrod moves the lever further away from the ideal of being parallel to the transmission case.
Where do you get these ideas?
Ideal is parallell to the transmission case at half its travel. (ie, when the clutch handle is half way to the handgrip)
A bit more forward or a back from that is no big deal.
Right now IT IS TOO FAR FORWARD, THAT'S WHY it's touching the frame.
R65 Rob wrote:Wouldn't I need to heat it up to bend it? And then, would I be changing it's temper and need to consider things de re metallica?
You won't have to bend it, the adjustment will fix it.
Wanna bet?
Re: bending
Posted: Fri Aug 27, 2010 9:37 pm
by Deleted User 61
"IF, and only IF, all else fails,"
I'm sorry, I missed that precursor.
Posted: Fri Aug 27, 2010 10:17 pm
by gspd
SO, is it fixed yet?
Posted: Fri Aug 27, 2010 10:51 pm
by Deleted User 61
I'm at work. All I can do is dream.
Posted: Fri Aug 27, 2010 10:56 pm
by gspd
R65 Rob wrote:I'm at work. All I can do is dream.
Have you ever considered....errr...mmmm............WORKING?
Posted: Fri Aug 27, 2010 11:02 pm
by Deleted User 61
Uh, I'm up to date on all my work. Just waiting for the next ... climax ...(when Step1 finishes and Step4 starts).
That is in about 1 hour.
