Converting to electronic ignition
Re: Converting to electronic ignition
A points system will start with lower voltage than any electronic ignition.
As far as "running better" goes, there might be other problems that caused this. I had more trouble getting mine set-up properly at first but after that, no further adjustments. The initial adjustments took a LOT longer than just setting points!
rapide
Converting to electronic ignition /brakes
Post by rapide »
Now on the front wheel, you can keep your drums and give me a couple 4-piston calipers on dual discs, TYVM.
[img] http://s67.photobucket.com/user/1951ott ... rt=6&o=242 /img]
NOW what i'm trying to do is add my stock points set back on my restored and newly equipped EME alt & ign. set up as an emergency back up just incase the new age stuff fails when I'm headed back to the 50th anniversary R90S rally i just returned from last week.
boy, it was 6700miles left coast to east coast and back and a fun ride.
my 74 R90SRS
