Page 5 of 13
Re: 5 speed ribbed tranny rebuild
Posted: Sat Nov 03, 2012 7:31 am
I've pulled 5th gear off......can't see an X so at least I'm confident which gear to get.
I've decided that I will in fact go for the taller fifth.
Prolly order all the stuff from M'bins tomorrow.
Too many reds now, I'll order too many bits.
Posted: Sat Nov 03, 2012 8:33 am
by Roy Gavin
If you had to use a puller to get 5th gear off you might need a new shaft too.
Posted: Sat Nov 03, 2012 4:38 pm
Roy Gavin wrote:If you had to use a puller to get 5th gear off you might need a new shaft too.
I did need to use a puller Roy, and use a little heat from my mini propane torch.
I did wonder about having to 'pull' a bearing that was retained by a circlip. Should I call the fire brigade?
Posted: Sat Nov 03, 2012 4:48 pm
ME 109 wrote:Roy Gavin wrote:If you had to use a puller to get 5th gear off you might need a new shaft too.
WHOA! peddle backwards, lucky I didn't call the fire brigade!
It's Sunday morning, 7:45. That's my excuse.
I meant I had to pull the bearing, not the GEAR.
I knew there was more to your smiley face....
Posted: Mon Nov 12, 2012 3:00 am
A package arrived today from Motobins which I've yet to open...
I do believe there is a taller 5th in there.
Gotta get this rebuild right.
Posted: Mon Nov 12, 2012 5:53 am
by Deleted User 287
Let me know if you want me to fly over and help out.
I usually only make the same mistake once. Twice at the most.
Usually.
Posted: Mon Nov 12, 2012 5:55 am
Hey that'd be fun Rob, and then we could go over and see Charlie.
Posted: Mon Nov 12, 2012 7:38 am
by Deleted User 287
Oh man, I could muck up the whole island!
The things I've seen.
Posted: Sat Nov 17, 2012 1:18 am
Posted: Sat Nov 17, 2012 1:32 am
by Garnet
That's quite the pile of shinny gears ya got there. Is that tall 5th gear gonna fit in there?
