No, not right. Always check the valves for change. If you have a change, then very carefully check the torque. Of course for the first check after assembly, then I would check the torque, and then adjust the valves, but that is only the first time.Bamboo812 wrote:You should have re-torqued the heads before adjusting the valves...
Checking the valve lash is like checking blood pressure, it is an indicator. You wouldn't take your blood pressure medicine first and then later on check your pressure.
Few know what valves are about. Few know how to properly set them. Few know how to check them. Go to http://www.w6rec.com/duane/bmw/valve/index.htm
