Now if there is something to complain about with regard to the head bearings, that's my candidate!ME 109 wrote: Poor engineering seems to often result in very little 'lip' available to get a proper tool in there to drive/pull the outer races.
I agree.Chuey wrote:Now if there is something to complain about with regard to the head bearings, that's my candidate!ME 109 wrote: Poor engineering seems to often result in very little 'lip' available to get a proper tool in there to drive/pull the outer races.
I am guessing that is what he used, but indeed there are a handful of things/ways contrived to do the same thing on the same spot. I used several devices in doing my last, I also jotted down somewhere (lost in the move right now...) a drawing and dimensions for something that I thought would work better than the scarp angle-iron sort of methods that accomplished the task at hand the last time. If anyone is all that concerned, once they are found, I'll publish them with a bunch of other "nifty" prints... (Both my designs and those old German Matra's... )Duane Ausherman wrote:Please explain how you did this. The torque relief bar is the best that we could come up with all those years ago, but I would love to learn a better way.ME 109 wrote:Tightening the 3 top nits seems to be the main cause of a good alignment process going bad, even with a torque relief bar. ime.
Yes, nits. I did a lot of head scratching to work out how to counter this problem, but counter it I did.
With mine there was insufficient 'lip' to use a screwdriver but this worked a treat ...dougie wrote:I agree.Chuey wrote:Now if there is something to complain about with regard to the head bearings, that's my candidate!ME 109 wrote: Poor engineering seems to often result in very little 'lip' available to get a proper tool in there to drive/pull the outer races.
I had to carefully cut almost through mine, then crack them with a punch!
PITA!!!
That's excellent - will keep it in mind for next time.Airbear wrote:It's a length of 8mm stainless rod, bent and then cut. It's a punch that can see around corners.
Firstly, I did use a torque relief bar. But what I found was that when the forks were spot on according to my piece of glass, torquing the nuts moved the forks out of alignment.Duane Ausherman wrote: Please explain how you did this. The torque relief bar is the best that we could come up with all those years ago, but I would love to learn a better way.
You gotta love a bike that can be fixed with a 6' length of timber!ME 109 wrote:I used my bent legs and a 6' length of timber to bend it back.
Those '81 triple trees are mighty strong!dougie wrote:You gotta love a bike that can be fixed with a 6' length of timber!ME 109 wrote:I used my bent legs and a 6' length of timber to bend it back.
