OK, the 1200 mile report! I took a couple days to go here this week:
A nice spot. Camped out a night:
There's a big pool inside the steel-sided building, and smaller pools outside. Clothing optional after 9 PM!
The bike ran great. Lotsa power, pretty steady on his feet. BUT the fork was all stictioned up by the time I got home. As in, it would dive on the brakes, and then only come back up under power. So I couldn't wait to rebuild the fork like I'd planned.
So while I had all that room with the fork out of the way, why not move the Dyna ignition over from Ernst and get the dual plugs going? Sure! Great idea! Now, because the flywheel had been lightened and all timing marks except F had been removed, I felt the need to check TDC and mark the flywheel at that spot. Unfortunately, the plug took the threads out of the head as I removed it:
Undaunted, I made my TDC mark and checked valve clearance (just down to .007 on one exhaust and up to .005 on one intake, just fine!), then took the carbs, exhaust, and heads off. I'll pull the pistons and cylinders later for new rings and a glaze breaking hone. Here's the right cylinder, actually the worse one:
And the current state of Edgar:
I'll be de-crusting the valve covers while the heads get repaired. Also rebuilding the forks and head bearings, installing the Dyna ignition and coils, building some new spark plug wires, and new pushrod tube seals when the cylinders go back on.
