Mrs. Jeff did have actually, but she took it out and we ate it for tea.
The electric heat gun is a good tool for heating and removing/installing the cover.
The cover is slightly bowed.... I realised that early in the piece.
Seems my troubles came from aiming for just under .05mm, and averaging measurements.
I have read that the method is to take four or more measurements for each bearing and then use an average as your base measurement.
Looking back, I can see that is the wrong thing to do.
Multiple measurements around the cover plate bearing pockets and shim plate, and essentially use the shallowest measure from the cover, and the shallowest from the shim plate.
I got it back together using reassessed measurements and the input shaft spins freely.
I believe all end plays are at .05mm and my shim assortment allowed me to match my measurement requirements.
I'm ready for Charlies tranny now.
The proof will be in the puddin'
