Krauser S Set rack - blinker mounts
Posted: Tue Dec 07, 2010 1:21 am
by Steve78RS
Hi folks
Has anyone a photo of the Krauser S Set (die cast aluminium) blinker mounts. Just the small tube thingy that inserts into the blinker. See what I'm talking about below.
I've lost my originals and I'd like to make up a new set. Some scale would be appreciated.
Steve from Dubbo
Re: Krauser S Set rack - blinker mounts
Posted: Wed Dec 08, 2010 1:26 am
by 2valve
hi steve, just had a look at my spare set of krauser frames , but sorry those parts arnt on it , just the long arm that the blinkers go through. if you ever need a set you can have them.
Posted: Wed Dec 08, 2010 10:10 pm
by Steve78RS
Thanks 2Valve
Yes I have the two arms that the blinkers are attached to. Thanks for the offer.
Steve
Fabricated Mounts?
Posted: Thu Dec 09, 2010 6:14 am
by Ken in Oklahoma
If it turns out that you have to fabricate the turn signal stalk, I can tell you that the tubing used for the BMW fork mounted turn signal stalks (and the tubing used other places) will tap nicely with a 1/2" x 20 TPI tap. Modify a bolt by drilling a hole through the center for the wires and you've got a mount of sorts. And you've already got the notches for the turn signal housing.
Also, light fixtures use 1/2 x 20 TPI hollow threaded rod for holding light globes and other applications. Fabrication potential is there too.
Posted: Sat Dec 11, 2010 7:08 pm
by Steve78RS
Thanks Ken
Simple really after reading your advice.
10mm bolt drilled out. Purchased a 10mm coupling (see below)
Then attach to frame like so.
And hey presto we have a more than functional replacement for the OEM set that I foolishly lost.
Regards
Steve from Dubbo
Posted: Sat Dec 11, 2010 8:32 pm
Not to mention being galvanized as well! Nice fix Steve.
