starter issue
Posted: Sun Apr 06, 2025 7:10 am
by dave_A
Hi, I'm new to the forum, apologies in advance if this issue has been covered previously. I have a problem with the ignition/starter motor system not disengaging on my 1971 R60/5. Pressing the starter button, the starter motor engages but won't disengage, even after letting go of the starter button and removing the key from the headlight unit. The starter motor keeps going until the battery runs flat. I have removed the starter motor and bench tested it - everything seemed to check out, it works as it should. I reinstalled the starter motor and the bike started as normal for a very brief period but then the problem returned, as soon as I connect the battery terminals - after recharging the battery - the starter motor kicks in. A few years back the starter relay failed and I replaced it with a generic relay - that set up's been working fine until now, I don't know if it's related to my current problem. Any advice is greatly appreciated
Re: starter issue
Posted: Sun Apr 06, 2025 9:10 am
Maybe that generic relay is stuck. Give it a whack and see if something changes?
Solenoid stuck?
I seem to remember the ignition switch might cause this too. Dragging my memory though and don't bank on it!
Does it have points still?
Willkommen, by the way!
Re: starter issue
Posted: Sun Apr 06, 2025 1:42 pm
by gspd
Your switch (starter button) or your starter relay is probably faulty. Small possibility is that the solenoid itself is faulty, but that type of failure is quite rare. Pull the black wire off the starter solenoid terminal and assure yourself that the starter works normally when you jump that solenoid terminal to the battery positive. The starter button and relay can be tested with a simple test light. No fancy equipment needed.
Re: starter issue
Posted: Mon Apr 07, 2025 4:06 am
by dave_A
Thanks for these, I'll check the starter button and the relay. I let you know how it goes.
Re: starter issue
Posted: Tue Apr 08, 2025 5:53 am
In passing,
When you replaced the start relay, you say you used a generic relay. Was this specified for use as a starter relay or just a normal accessory relay. The starter circuit draws a considerable current and a the OEM relay is rated at 60 amps. An ordinary accessory relay is probably not powerful enough and can weld itself shut. Doesn't need to be an OEM relay but it does have to be rated at 60 amps...
Re: starter issue
Posted: Sat Apr 19, 2025 5:56 am
by dave_A
I checked the starter button with a continuity meter, it appears to operate as it should. However reading about the possible relay issue - the generic one I have mounted is rated at 40 amps. Thanks for this, I'll source a 60 amp one and report back.
Re: starter issue
Posted: Mon May 05, 2025 1:20 pm
by dave_A
I found a 60 amp relay, but unfortunately the starter motor kicked in again as soon as I connected the battery. When this happens, when I hear movement in the starter motor I disconnect the battery leads quickly, fearing the starter motor won't disengage if the engine starts. Out of curiosity and pondering where to look next I pulled out the relay and connected the battery and still the starter motor jumped into life! I suspect I must have a short somewhere. Or could it be that the solenoid is stuck? Thanks, D
Re: starter issue
Posted: Mon May 05, 2025 3:14 pm
by gspd
You have to remove the gas tank, air box and starter cover and have a look if there's anything obvious like a pinched or burnt wire.
If the starter activates with the small black wire to the solenoid disconnected from it, you need to replace or rebuild the starter.
The thick wire to the starter is direct battery power, the small black one should only have power (via the relay) when you press the starter button.
Re: starter issue
Posted: Tue May 06, 2025 5:31 am
dave_A wrote: Mon May 05, 2025 1:20 pm I found a 60 amp relay, but unfortunately the starter motor kicked in again as soon as I connected the battery. When this happens, when I hear movement in the starter motor I disconnect the battery leads quickly, fearing the starter motor won't disengage if the engine starts. Out of curiosity and pondering where to look next I pulled out the relay and connected the battery and still the starter motor jumped into life! I suspect I must have a short somewhere. Or could it be that the solenoid is stuck? Thanks, D
OK, I think it's highly likely that the solenoid is stuck or welded closed. Quick test... disconnect the battery positive. Remove the battery lead from the starter. Take a regular jump lead. connect to battery positive and (carefully) touch the other end to the battery terminal on the solenoid. If the starter kicks in, the solenoid is definitely short circuit... you've eliminated all other components. You might be able to dismantle it and get it working again but I'd recommend replacement of the solenoid at least.
Re: starter issue
Posted: Tue May 06, 2025 11:26 am
by dave_A
Thanks Rob and gspd, I'll get back in the garage in a few weeks and have a good look at the starter/solenoid. Fingers crossed, we've found the problem.
