1982 R100RT - Replace Left Handlebar Controls
gsm_r100rt
Post by gsm_r100rt »
I need to replace the Left Handlebar Controls. I see that the wiring goes to the front light bucket. Will I be able to do this by removing the front glass on the fairing and removing the head light? Or will I need to remove the front fairing for more access? Any sugestions on how to navigate the rats nest inside?
Any info appreciated :)
Re: 1982 R100RT - Replace Left Handlebar Controls
Willkommen. :)
Tools. Phillips head screwdriver, needle nose pliers or a haemostat forcep.
Fairing glass out, headlight lens out. You're in.
1. The glass. Lift each internal corner of the headlight rubber to reveal the screws. Remove each screw. Lift the rubber headlight tunnel out.
2. At 6 o'clock, there's a small screw. Tilt the headlight up a little for better access. Loosen off the screw and allow the clip to release. Don’t remove the screw, just loosen then remove the chrome surround & headlight lens, disconnecting the bulb at this point. Take note how this all comes off (the notch at 12 o'clock) as you'll need to reattach. It can be fiddly.
3. Then sit in front of the headlight and work out what is what. It is very ordered and colour coded despite the initial :shock: . The forcep replaces fat fingers! :o
Ignore those loose wires in the picture...you'll work it out when you open yours.
Everything is colour coded and plugs into this board...or relays.
Brook takes you thru the whole rewiring...
https://youtu.be/ZwIu3xxnWMo?t=1418
The headlight goodies are within the perforated lines in the left...
81-84 R100RS.JPG (447.16 KiB) Viewed 3117 times
On a RS it's a matter of feeding the grouped wiring thru a hole in the headlight bucket. Remove the current one with a string/tracer attached at the front so you can attach it to the new one and pull straight thru. You might need to finesse the individual wires thru the hole initially.
