Hi from London England!
Posted: Thu Jul 17, 2025 4:00 am
Hi all
Greetings from London, UK.
Returning to motorbikes after a 15 year gap following arrival of children.
Picked up a 1978 R100RS which has had the fairing and bars replaced, as a sort of rolling project to bimble about on. Based on the MOT history, it has done very few miles since 2005 when it was on around 74k miles. I've a ream of receipts for various bits from 2016 when it appears to have had a going over by a previous owner - lots of fixings replaced, bits of final drive and some carb parts. The vendor put in a new battery, checked the compression and replaced the pushrod seals. Engine and frame have matching numbers.
A couple of known issues and no doubt a load of yet to be found....
Managed the trip back from NE England to London OK, brakes were not as bad as expected, runs beautifully up to around 60-70mph where there is an intermittent fuelling issue, the seat isn't quite straight (hopefully not the subframe, the bike tracks ok), Am also seeing an oil drip from the RHS carb. Its on ancient tyres so I didn't venture much beyond the indicated 70mph in a straight line..
New tyres are ordered awaiting fitting and this weekend I plan to open up the carbs as I've some replacement diaphragms, and have a look behind the front cover to see what sort of ignition system lies within..
Anyway here's a pic - its more comfortable than my R1100S was, handles like a shopping trolley if you don't set it up carefully for a turn, and needs advanced warning of a stop, but I'm so far loving it
No doubt lots of questions will follow.
Best
Ade
Best
Ade
